Chart to go up later...
But was running Tesco 99 with Millers Octane Booster and 1.5 bar boost (peak of 1.7 bar)....
Time Attack - ESC Race Car - Alive & Kicking!! + Power G
mike-payne
mike-payne
Unlikely no.....pablo wrote:Nice figures Mike glad to hear that it's all back together and working again
Will you be doing TA next year.
Several reasons...
I don't have a local tuner for support
Costs have been extreme
I didn't like the format this year (probably more my fault in that i'm too competitive. But i could get more track time and fun doing track days)
Despite all the promises again... we still don't have a confirmation of the format as promised back in August!!!
Car is now for sale on eBay & PH
mike-payne
Can't make my mind up.......pablo wrote:Sorry to hear thatbut at least you're not giving up the track days
So what's on the wish list to replace it
Something like a Caterham, Westfield, Super 7 style kit car
or possibly an AC Kit car look alike, with a nice big V8...
really not sure..... if i go the Caterham route, then i may well take up sprinting..
I also considered sprinting the scoob if i didn't get any bites..
mike-payne
good to see you getting it there................
what sort of spec/cost is the car currently as i'll mention it up this end??
mike-payne
Thanks Alyn....stockcar wrote:good to see you getting it there................
This is copied from eBay:-
This is my track / race developed car. It has competed in the "Time Attack Series" for the last two years.
The specification of the car has always been aimed at track use with reliability. Therefore it's not running extreme power, but a very usable 427 Bhp with similar torque figures.
Work commitments don't won't allow me to compete again next year, so I've decided to sell the car and move on...
The full specification of the build is below, although I'm sure there are items that I will have forgotten or missed off...
Full Engine rebuild 2nd qtr of this year and compression tested again in October.
Forged 2.15 stroker engine
Closed deck 2.0L block
2.5L Crank shaft
Wiseco Stroker pistons
Crower Stroker rods
ACL bearings
11mm ARP head studs
Steel head head gaskets
Baffled sump (custom made)
STI V5 heads with new seals and valves re-seated and shimmed
STI V5 red top manifold (painted blue)
Reversed throttle body to suit V1 car
Raised manifold gaskets to reduce heat soke
Custom parallel fuel lines
Lateral modified 450 injectors - now flowing 850
Roger Clarke Modified oil pump
HKS front mount inter cooler
MD321S turbo
Oil Cooler
GT Spec 2 SS headers
Custom large cold feed intake system
3" straight through exhaust (de-catted)
Lightened Crank, power steering & alternator pulleys
Alloy catch tank, with sump breather acting as a drain back to sump
STI Type RA quick steering rack
Type N engine and gearbox mounts
Simtek ECU with Launch control and anti lag
Simtek dongle and software for above ecu
Apexi AVCR boost controller
Defi gauges and controller for Oil temp, pressure and boost pressure
6 Speed Uk Gearbox, diffs and shafts
AP 6 pot front callipers, rotors and discs
Pagid RS15 front pads
Brembo STI 2 pot rear Callipers
Pagid RS29 rear pads
Tein Full Flex Coilover suspension, Includes adjustable front top mounts and camber bolts all round
Polybush complete replacement bush set
Whiteline front & anti roll bar 22mm (28mm front and rear available too)
Rear drop links
Modified pick up points for front drop links
Custom brake cooling ducts
Walbro uprated intake pump
Separate swirl pot with bosh fuel pump
Carbon fibre rear boot firewall
Interior stripped - no rear seats or trim
Corbeau FIA approved bucket seat drivers side, with bride adjustable seat rails
K-Sport passenger bucket seat fixed
4 point FIA harness for driver & passenger
Adjustable steering wheel boss
Air con removed
Bolt in 6 point roll cage and FIA padding
1 set of 17" Roto wheels painted black with toyo R888 tyres
1 set of Speed line wheels powder coated black with Toyo T1R tyres
Full set of light weight racing alloy wheel nuts
***LISTING UPADTED 21-11-2008***
Listing updated to show a Dyno power run on 20-11-2008 to support the quoted power figuers
blackskygtr
I dont want to hijack the thread but why is it that these scoobs seem to develop nearly as much if not more torque than hp ?
Duncans is an extreme example but your car is almost the same
Have i been asleep for the last 5 years ? It always used to be the domain of the V8 etc to have the hp /lbs upside down but that does not seem to be the case any more. Are there many other cars that operate this way?
Super car bet you will be sorry to see it go. My weapon of choice as a pure track day car would be a sylva with a V8 :twisted: Racing series proven and not silly money. Good luck whichever way you go
Jay
Jay
