Project STi Time Attack
mike-payne
Might see you there too.... should be meeting YVM there @3.30 for him to get his car and i'll be leaving mine behind.dynamix wrote:That is the plan but it I find it easier to concentrate when driving quicker on track so will just go with the flow and drive it like I normally do.
mmmmmmm
mmmmmmm just got back .... mmmmmmmmmmmm
full details later 8)
first ... a bottle of wine 8)
"1,2,3, 4, 5 senses working overtime"
How good are EXE-TC ???
let me tell you .................. fekking awesome 8)
Had the geometry redone aswell and now running:
Front :
2.25 degrees neg camber
5.5 caster
a touch a toe out
Rear 1 degree neg camber
a touch of toe out
Rails on Corners Goes is Like it round (rearrange these words)
Cheers Zak, Luke and Alyn at ASP for the hardware :thumb:
Front :
5.5 caster
a touch a toe out
a touch of toe out
mike-payne
Congrsts Dunk and co. Look forwards to hearing the results after Monday
EXE-TC are the bollocks Dunc
I've driven an Evo IX EXE-TC RM04 equipped, it was so compliant yet sooooooo grippy and confidence inspiring. But also soooooo expensive!!
I almost bought the INTRAX set up (which use the same casings, and alledgely are the same as WR04's) but plumped for something slightly cheaper in the end. EXE-TC will be awesome at the ring
:twisted:
yagshamash!
