So who's got the quicker car then?? Gerry or Duncan??
This one i would like to see!! 8)
We'll find out when you bring your car out for an event. When's the last time you did anything, other than scare some old ladies in the High St?ScoobieWRX wrote:So who's got the quicker car then?? Gerry or Duncan??
Too much keyboard bravado. Get walking some walks mate :-D
I second that emotion!! :evil:Gerry H wrote:Doing the VAT return that needs finishing and in today.Pike wrote:Mr H you are on fire today!
VAT = Grumpy Bastard
Re: STi Time Attack 2008
Just looking back at where the car came from to see just far has been come over a short period of time.dynamix wrote: Current Issues that I am aware of:
1) Fuel Surge .... about time really, I was feeling left out from the Subaru community by not having had this to any extent- now I get it on high G right handers and is a cause for concern that needs solving.
2) Body Roll .... having looked at pictures of me, I feel that a little less body roll will help the handling on the limit on track
3) Power .... more is almost always good
In what is essentially my daily driver still, all of the initial 'issues' have been solved along with others along the way which always appear when you push the envelope as Stu puts it.
Fuel surge was well and truly cured
Handling is awesome now
Power is right at the limit of what I can use on the road (i feel)
Loads more to do and possible to do, but just taking some time to reflect on what I have done over the past 12 months. The 'done' list is huge !
Closed Season done at Area 52 Autosport
1. engine build
2. cusco clutch
3. FP Green turbo
4. fit APS FMIC
5. remove emissions systems
6. TGV deletes
Donington:
1. fit and map with avcr
2. lower car further
3. fit steel wheel nuts
4. replace osr wheel stud
5. paint spare set of wheels
6. car to Area 52 for check up
7. apply TA stickers
8. fit 01 brake pads
9. final fit of front splitter
10. remove speakers / stereo
11. fit drivers bucket seat
12. fit 4/6 point harnesses
Knockhill:
1. relocate oil catch can
2. roll cage
3. change all IC clamps for heavy duty ones
4. fix electrical issues
5. fuel swirl pot and additional fuel pump
6. Zen mapped due to fried ecu
7. Fit Cosworth Oil Baffle
8. replace oil pipe up pipe
Dyno Showed 465bhp
Silverstone:
1. Fit oil cooler
2. Heat Shield for IC pipework
3. Quick release for bumper
4. Up rev limit to 7500
5. Change Oil
6. Bleed Brakes
7. Air Duct to induction
8. IC pipework alignment
Oulton:
1. Heat shielding on hoses
2. Fit canards
3. Re-do all IC pipework and fit complete uprated clamps
4. change brake pads back
5. fit DZUS pins
6. swap thermostat
7. fit switch for fuel pump
8. fit own ecu and map
9. fit rear diffuser sides
10. HTA green turbo
11. Braided oil feed to turbo
12. oil cooler boxing
13. bodywork revisions for oil cooling
14. re-work wiring for Phormula KS3
misc & post oulton crash repairs:
1. re-make oil cooler ducting
2. fit larger oil cooler
3. change wishbone
4. replace whiteline ball joint
5. replace performance friction front brake discs
6. replace whiteline track rod
7. replace abs sensors
8. suspension geometry set
9. raised by 6mm (for the ring trip)
10. continual mapping tweaks
11. change to uprated gearbox mount
12. airbag fix
It seems gradual when you are doing it but looking at a long list of stuff done it is quite daunting and I am sure there are things that werent noted
Thoughts are now with the impending ring trip and the last TA event of this year and planning for next year and what to do.....
Whats your thoughts for next year Dunc, you goning to do TA again or something else??
I am at a stage where I am wondering what to do. I know I "need" to do motosport of some form but not 100% what, whether I continue with teh Sprinting doing the AEMC ASEMC and maybe the All Circuit Championship I didn't enter this year, of do the MLR Sprint series, or maybe sack it all in and go do some form of racing....... :?
