TNTRacing - XRCosworth
Re: TNTRacing - XRCosworth
What a pain in the arse. So, was the OMEX ever working properly or has it started to stop working? (If so what's changed?) When is your next outing with the car?
The omex is working just not really contolling anything. If you get what I mean. Our next outing is this sunday at Ford Fair and then we were planning on time attack, but only 15psi to play with theres no real point in that.
As best as i understand it. Alan understands it better than me but here goes.
3.62 diffs meant engine revved up slower allowing boost to climb
Boost leaks were acting like a bleed value, again allowing the boost to climb. To an artificial 26psi.
3.92 diffs engine revs up quicker not giving boost chance to climb
Boost leaks all fixed so no artificial bleed value allowing boost to climb.
Same wastegate and spring we ran on Herbie (red car) and that only made 15psi.
Beyond that I left Alan to speak with Richard (mapper)whilst I was talking to Brian (Owner of RGS).
- jap.slapper
It must be very frustrating for you guys but it'll come good in the end I'm sure
You have no idea just how p***** *** we are. A brand new Omex thats basically doing f*** all. From what i got from the conversation this afternoon we're basically running the same setup as we were with the first car.
From what i understand the only thing that has stopped us blowing the engine up is a plastic restrictor in a boost pipe as when they removed it (Doing their checks and tests), it over boosted like a bitch.
so lets cut to the chase, they had car for some time, cant fix issues,pulled all boost control to make just 15psi.
sorry pablo but sounds liek you out fry pan and into fire with another tuner.
my offer still stands
- jap.slapper
I hope you manage to get it sorted either way chief
gary@apt wrote:so lets cut to the chase, they had car for some time, cant fix issues,pulled all boost control to make just 15psi.
I don't expect you to air you tuner woes in public (I don't actually think it's good practice to do so) but at some point Team TNT have to decide whether you're getting what you're paying for. Time to take a dump or get off the potty
Now imagine if we had taken the car to you, Gary, for what we thought was going to be a bit of mapping and you came across that lot. We would have felt like a right pair of idiots as if we were taking the piss.
