My SWB TT Z32...
Spot on
- Monster
You've certainly swung into action there chief, since the decision was made as to which way to go. Good stuff.
The simplified engine bay and extensive use of heat shielding will definately pay dividends long term.
My only word of caution would be around binning the lights, especially if you do it to the degree that they're not easily replacable. Only because many championships insist on stock lights for some reason - I remember when I was driving the old SE Nissan S12 Silvia in Mod Prods, we changed the pop ups and the scrutineers very nearly didn't let us run the car - which would've been a fookin nightmare as we'd trekked up to cadwell!! So leep at least one eye on usability of the car once finished, you may not want to do TA for ever.
Otherwise storming progress chief
- jap.slapper
Well today was a bloody howler up here, after only an hour working on the zed the heavens opened and the winds picked up, though strangely it didn't bother me today
the following is a bit picture heavy
so first things first, I got cracking on stripping down one of the turbos so that the housing could be sent of for machining
You can see here where the one housing inlet is larger than the other, God knows what the 'Zed specialist' in question was thinking?
Stock engine mounts came off
the stock mounts are being binned for a pair of AMS engine mounts
then it was back outside to start tackling the copious amounts of unnecessary Nissan pipework
first on the list was the PAS hard pipes
the PAS pipework literally runs all the way around the engine bay for no apparent reason other than to complicate things?
this has all been binned and a single length of hose will run from the PAS pot to an Evo 4 PAS cooler (mounted inside the front bumper) and will then run directly back to the rack
We will use a similar PAS cooler to this one
*the JDM z32 doesn't come with a PAS cooler as standard so I figure it was easy enough to fit one as the engine was already out and the rack was easy enough to get to
the PAS pipes were all cut out and then we capped them off for protection until the cooler is fitted
next on the hit list was the clutch booster, this was inside the engine bay....
this crap was tucked away outside the engine bay behind the drivers side fender
all of this is now in the bin!
all of the clutch hard pipes and 'T' pieces have now been removed and will be replaced by a single braided clutch hose that will run direct to the slave
then it was on to the spiders web that are the fuel lines....
http://s1034.photobucket.com/user/azineakinadan79/media/videos/IMG_0623_zpsc4354941.jpg.html
again, loads of excess pipework has been removed. The plan is to run new fuel hoses direct to the new Fuelab filter, fuel damper and Fuelab FPR bypassing all of the stock lines that have now been removed
temporarily capped off for protection
more to come, I'm just uploading some more pics
- jap.slapper
then back into the workshop to give the AMS manifolds a quick wipedown
there's quite a difference in size between AMS (top) and stock (bottom)
- jap.slapper
- jap.slapper
This banjo bolt needed a bit of persuasion
but a few taps with a BFH released it
http://s1034.photobucket.com/user/azineakinadan79/media/videos/IMG_0625_zps98fe5217.jpg.html
The postie dropped these off this afternoon
so the plan was to relocate both of these
this is how it will all bolt together
I'm pretty chuffed with this setup and it's 'mm' perfect
Great advice from Monster on the headlights
Made that cock up myself before with a previous project.
- jap.slapper
Stuart wrote:Great advice from Monster on the headlightsMade that cock up myself before with a previous project.
Yeah I'll keep them in a box just in case and won't cut out any of the required wiring but will run with the much lighter and simpler Westfield kit in the meantime
