Well have had a guy come and look at the engine and carbs for me, a lovely chap called Steven James has his own small business specialising in the older and classic vehicles, he comes to your house and works so great if you cannot drive your car anywhere, really knowledgable and put up with and answered every daft question I threw at him, cannot recommend him highly enough.
He set the timing and adjusted the carbs a bit and decided carbs would be best to have service so he took the carbs and cleaned them all up giving me an A4 sheet of things which were wrong that he had sorted out came back and refitted them and reset the timing. she was still running like bag of nails, so had a further look at the distributor and discovered that it still had the original dizzy for an injection engine ie very little advance hence only being able to get it to run well over only 2000 revs of the full range. Then went from bad to worse when went to adjust the dizzy and discovered it is about as good a a chocolate teapot!!! Vacuum advance was giving between -7 and + 35 pretty much whenever it felt like it!!
Now probably going down the route of a megajolt system to do away with the dizzy. Not ideal or my original plan but probably by far the easiest and best system available and will make it easier to adjust in future.
However it won't be being done now as unfortunately MOT runs out and after a bit of investigation of the so called solid drivers footwell and the removal of large amounts of expanding foam and filler don't think she'll pass!!!!!
To be honest was never the plan to put her through another MOT would cause to much more damage/rust over the next year. So after having never actually got to drive her running properly just got to hope I love her as much as I think I will from the trips we have had, when she's finished!!!!!
So just as a reminder of her current state and as a fitting end to the whole will she, won't she run properly before the rebuild (and in true Manta fashion she never did!!!)
So next step when all has calmed probably in the next month or so after wedding I will start the destruction ooops sorry restoration !!!!:D :roll:
Suz
