Engine, brakes and tyres.
Engine
Before RGS Motorsport up the boost we wanted to give the engine some 'good loving'. Recording water & oil temps and oil pressure after each session (7 in total). Along with this we also monitored the oil level and new catch tank set up.
All info to be passed to RGS next week
Brakes
Alan had fitted some brake ducting to help with cooling of the brakes. Throughout the day we had Zero brake fade or drop off in braking performance. Yesterday we pulled the pads out to check for heat damage and the pads look fine at the moment. Although we will be checking them after our next outing to gauge how many events we can use them.
Tyres
Prior to the day Alan took off the front arches and raised them by 10mm to give a bit more clearance to the larger tyres. We did have a bit off rubbing in the morning but this was soon sorted with a file and hammer
Overall we are very happy with how the tyres performed except for one thing.............Damn they're noisey, even from the pitwall. As the car went past it wined as if it had a supercharger fitted
One of the best days we've had with this car and about bloody time too.
