Could be Gerry but it does feel hot to the touch all over with no difference top to bottom.Gerry H wrote:IMO your cooler isn't filling as the air can't escape, The oil won't push the air from the upper rows.
Runs hotter than expected again IMO.
I tell you what it is that is making it run hotter - the undertray. Since that went on the oil temps went up about 8C as opposed to free flowing air around the sump.
I will see what it is like on track and make any necessary changes between oulton and cadwell next week.
Then again it could be these crappy SPA gauges I have that throw out some weird made up figures sometimes. (long story but I feel another sensor is about to go... grrr)
Had that with the Defi oil temp. Toodling along and suddenly the reading goes off scale and the infernal alarm can't be cancelled :x
Maybe when you change your oil, feel how the heat flows through the cooler. After a run it'll all be hot regardless.
Yeah - just done the oil change.Gerry H wrote:Had that with the Defi oil temp. Toodling along and suddenly the reading goes off scale and the infernal alarm can't be cancelled :x
I read the info on that thread on 22b and that didnt say not to mount this way. Not bothered at the mo anyway, far more important that I drive the crap out of it and qualify for the final. I am going to tape over the gauges as they only make me back off
Oulton Park Bit Me
Perfect weather for 888's ???
Some pics of the incident...
Starting to come out:
Snap back but pointing at the armco
thank god it didnt go in this way:
The impact... I knew it went up on two wheels.
How the heck there wasnt more damage looking at that
The aftermath:
Closer investigation of the damage from the accident have revealed how lucky I was. The silver scuffs that you see on the paintwork arent my paint, they are the paint from the barriers on top of mine so will clay bar out leaving remarkably few actual dents and scratches.
The front wing does need replacing but I was gobsmacked to find out that they are
