Mazda MX5 Turbo
hoodedreeper
Post by hoodedreeper »
It handles quite well (on a dry day ;) )
STS Tyre Pros down Riverside done the set up :) Will be much better when the rear camber is dialled out abit and i can get abit more tranction
hoodedreeper
Went to Norfolk Arena for the monthly drift practice. First time skidding properly since the car has been turbo'd. The day started off sodding wet with a very muddy track. Didnt take long to get back into the swing of things
The sun came out,track dried out and i was improving alot! First time i had linked the track several times,things were going well!
Until....
I spun out on the Kidney,facing the opposite way. BMW comes round the corner,luckily spotting i had spun so he slows down and straightens up. THEN he decides to clutch kick and hit me :/
The car wasnt running right,found out that the Throttle Position Sensor had lost both its screws and air was getting in. Borrowed a screw from something else and it cured it. I rejoined the que and carried on skidding till 5pm,then it was home time
Wasnt a bad day in the end,could have been worse. Could have been a rear 1/4
Must be such a laugh driving that around. :) As for the door and wing, as much as a pain it is - still repairable. Or leave it like many drifters do. :)
I miss going up there for a hoon. Sorry to see the knock but so easily done when bombing around on a very changeable surface (grip wise) Onwards and upwards eh Chris? :D
Doh, as you said, lucky it's not the rear quarter.
hoodedreeper
He tried blaming the track conditions...what...bone dry?!
Fool....
Where did this happen on the track then? The middle of the kidney bit? When I was last up there there were two pretty harsh surface changes and I used on to deliberately unsettle my car to enable an easier loss of traction (I used to use R888's)
hoodedreeper
Yup middle of the kidney
Heres the video from today,fast forward to 3min 30secs
http://www.youtube.com/watch?v=Xku3vkFpCiU
Tough to tell for sure mate but essentially he took a big risk by trying to slide passed you. Thank God panels for MX-5s are so cheap.
hoodedreeper
90% sure i'll be buying another car and transferring everything over. So if you see/know of any Mk1 1.6 in white or Marina Blue for sale let me know :) Even if its a non runner,as long as the shell is clean
