LOTS of wires and very very close together.
As soon as the car is back from ABW it is time for a proper ECU...
Solaris S6
Main features..
4 Individual Ignition and Fuel maps
Fully sequential control of fueling and timing.
Batch firing and wasted spark ignition.
Individual cylinder TDC definition
Idle control, closed or open loop
Cam control, closed or open loop, up to 4 camshafts.
Rpm limit : 20000 RPM
Fully configurable Data logging with individual choice of logging channels and frequencies.
Fully mappable Wastegate control, with gear dependent boost maps.
Launch Control - Retard and Fuel cut strategies.
Traction control - Fully programmable slip targets.
Drive by wire
Knock control
Full throttle shift cut - Open and closed loop, full programmable
Anti lag - 4 ALS Calibrations, EGT dependency, Jacked open throttle idle control, ALS Initiation strategy.
Full 3D mappable Nitrous control, Wet and dry systems.
Crankshaft/Cam Signal Oscilloscope with sync loss capture
User Programmable linearization of all sensor inputs.
Battery Voltage compensations
Upgradeable firmware
CAN Bus interface
Configurable I/O
Hall & VR Crank/Cam sensor compatible
Basically for me it means a few things:
1. I can run a 5th injector to add extra fuel needed for running 100% E85 (if that isnt a contradiction in terms)
2. Real time mapping
3. losing the MAF which is absolutely at it's limit at present and subsequently cannot control fueling as precise as I would like
4. Much more precision in the maps
5. switchable via a dash switch.
6. some toys such as ALS :evil:
I will also be able to switch closed loop fueling back on with input from my bosch wideband going direct to the ecu to control it - this should make it run a little smoother on daily duties and return better mpg.
I have no idea whether any additional power will be gained from this but I think the switch to pure E85 may net a small gain just from the higher energy. If it gets to 1200 combined bhp/torque then I will be over the moon but that is not the objective - I have enough power as is.
