Well done Chris (and Gary)
I knew you would do it (eventually)
the fellowship of the rings :-D mine will be the next to gogary@apt wrote:a bit more news
on a sunny sunday where's the best place to be .......at work doing a bit to the kit car,
today we got cooling system sorted plus wiring for fans and alternator
so we could run the engine for longer
on the down side it looks like while the engine has been sat its had some grit etc go in to bores,that means once we started it its damaged the rings as it smokes a bit!!!
not to end the day on a low chris decided to bolt a seat in it and manaully select first gear and have a test drive around the car park
so the GTM has been on its first trip!!!
poor chris was a bit down as we left as engine was bought with very little miles on it and should have been fine......
never mind mate you know how cars can give you so many rewards but then kick you in nuts!!!!
it will be fine..... :-D :-D
