Are you running a MT75 gearbox? If so you shouldn't be eating them at that rate. Could the fact that you are still running a standard crank be the route cause of you gearbox problems. Just a thought.
My RS Turbo - Plenum project (+ MORE!)
Excellant work there...We know you mean about not being to get certain parts for our old fords
We've being disussing tubular manifolds for the 4be, but would have to have them made up.
- Bladerider
Nice job Christian,
Can't wait to see your animal with this setup.
The offer still stand to take it up the 1/4 mile for you
Are you worried about any more lag. I think not!
I get confused between the MT75 and the MTX75, but the one I want is the FWD one of course, as used in the RS2000 AFAIK. ]Nice job Christian,Bladerider wrote:MT75 ???
Thats a cossie box is it not ???
J.
Are you worried about any more lag. I think not![/quote]
I am worried about more lag TBH!! I am changing from a 0.86 A/R T28 housing to a 0.63 A/R T3 housing (well a variant of anyway), so not really sure yet what the result of that will be. I also own a 0.64 A/R T28 housing and I like how it drives on that, but it doesn't make the transition to External Wastegate very easy.
Ian200sx wrote:Great project! very impressive![]()
Why don
no mate all sierra's from 90-93 all came with that gear box i have the same one on my GTBladerider wrote:MT75 ???
J.
the MT75 gear box was only put on sierra's and the likes of the escort RS2000 had the MTX75 gear box that sits on
the side of the engine were as the other sits under the car.
great car i like it and you carnt go wrong with a nice waste gate :-D
Update time.
I took the bull the the horns so to speak and decided to have a proper test-fit. Having built this new manifold set-up on an engine out of the car, it has been tricky to get everything right, but I really wanted to do this at my own pace and didn't want to take the car off the road.
So, after removing my Bumper/Intercooler/Radiator/Turbo/Manifold/Alternator etc etc, I fitted up the new manifold. Immediately obvious was a couple of minor clearance issues. Firstly, the manifold touches part of the bonnet bracing, but also it touches the slam panel. Neither are that bad, I could get the bonnet closed and the slam panel didn't prevent me fitting the manifold, but they do both need attending to. (Stilsons will sort the slam panel and an Angle Grinder for the bonnet!!)
Then I fitted the turbine housing and downpipe, which all fits remarkably well and clears the starter motor exactly as planned.
Next was the Wastegate. After relocating it from its original forward facing position seen in earlier photos, I knew it was close to the Vernier pulley and I have already made one further adjustment to the mounting position to overcome that. It now sits perfectly. I have also built the Wastegate vent pipe (Screamer), although this is currently only tacked. The Screamer is only a temporary measure too, I have further plans for that once I have seen this setup work.
So, with everything in place so far and looking really promising, I decided to build my turbo into the new Turbine housing as I was concerned about gearbox clearance and oil drain height. It turned out that there was no issue with either of these. I have to alter the Compressor Outlet-to-Intercooler hose and remake the oil drain, but those are incidental jobs.
Then I put the radiator in position and was very pleased at just how much room I have down there. There is now masses of room between the turbo and radiator. I could, if I wanted, move the radiator back a good 2-3" and make room for a thicker Intercooler if I wanted, but that's for another time!! LOL.
So, after a great result with the test-fit, I dismantled it all in preparation for the final few bits to be welded up.
So, for the next session, I hope to make some further progress with the Alternator remount. Watch this space.
You seem to have glossed over the percussive maintenance required to get the manifold to fit behind the slam panel. Piece of wood and a hammer?
It's nice to see a bit of thinking outside of the box. Your comments about Japanese car owners having it easy with choices is true up to a point. Because parts aren't readily available for some other cars, does that make those that tune them more resourceful because they have to improvise or are their choices compromised because there isn't enough testing??
Not having a dig, just wondered....
