How to keep yourself busy for a while ;C)
Nothing like a project to keep you busy
Looks good so far, look forward to the updates
Super project Mark!:thumbs:
I look forward to the updates.:)
slaphead
Post by slaphead »
russ979 wrote:Super project Mark!:thumbs:
Your wish etc etc....
Once the stripping was done with it was time to re-seal the original bodywork and factory primer with metal
paint,a first coat of stone chip followed by seam sealer and another coat of stone chip to provide a level
of protection sadly never applied to original Z's.
Looking good so far Mark. That will weigh about three tonnes when you've finished :D
Nice work!
There must be something in the air round these parts mate!
I think its funny that youv`e spent your christmas break working under a car too.:D
Good luck.
slaphead
Post by slaphead »
Stuart wrote:Looking good so far Mark. That will weigh about three tonnes when you've finished :D
ONLY when I'm in it lol :biggrinjester:
russ979 wrote:Nice work!
Good luck.
Sadly it wasn't under the Zed - a transit beckoned and I couldn't resist the call of the dark side!
slaphead
Post by slaphead »
Well after her winter lay up and a lot more fiddling about the old girl is now running on all 6 cylinders again (not just 3 - turns out the rear inch and three quarter SU HS6 was gummed up with emulsified fuel :sheep:) - plus what I had feared was a failed clutch actuator lever turned out to be be a missing peddle linkage pin - so no engine out (yet again!), and all associated hassle was not necessary, a bang on result!!
But having unblocked everything she is now running pretty well (a bit of distributor fettling aside) and sounding absolutely awesome.
Sometime think this car is a case of two steps forward and one step back, I seem end up re-doing stuff that has deteriorated since it was done lol :banghead:
Some more pics shortly gents ;C)
Mark
Forgot all about this Mark........need pics matey :)
Yeah deffo pics !!!
slaphead
Post by slaphead »
RX7 wrote:Yeah deffo pics !!!
Pictures will follow honest!
Still in the 2 steps forward 4 steps back club sadly
To bring the story up to date :-
Having replaced the leaky core plug (one of those sneaky ones that hides under the exhaust manifold) I rather foolishly/naively refilled the rad with water thinking job was a goodun and promptly got wet feet for my sins - another bloody core plug had gone!
When I checked the other core plugs they looked decidedly ropey so I bought a job lot and replaced all seven of them and refilled the cooling system yet again, hey presto no damn leaks finally!
I now thought it a good opportunity to run the wagon up temperature and see how she went [This is Mark speak for "I just wanted to hoon the damn thing around the garden sideways for a laugh"], anyway after carefully warming the beastie up, I started to stick my foot down and remember thinking that "blimey it seems to be wheel spinning easily today"
WRONG!
Forking clutch was sh*gged again and she was just spinning up at the flywheel! :beatdeadhorse5:
So I rather philosophically pointed it back at the garage and gave it enough rpm to get it there - as I arrived back at the garage the gods of "so you think your having a bad day (so far)" intervened yet again and as I got rather hot feet their cunning plan for me became clear, the heater matrix had just blown big style doh! :nopity:
The engine will be coming out again soon to do the clutch (it will give me a chance to clean the engine bay out properly after all) - I do have a heater matrix tucked away somewhere, so it may not be a big issue just an inconvenience.
Mark
