The BMW 535i engine donor has been lost for the project. I was made an offer for the car last week that it was too hard to refuse. I am sure something else will turn up to donate its engine, and I know the new Bimmer owner is going to enjoy himself in it. I also made a bit of cash on it, that paid for the new bead roller so I can now made my own floor and wheel tubs for the project. I also have someone machining me a tool I designed to cut Louvres on panels of any length I need. Expect to see it put to good use later in the project.
Back to the car itself, the next job was to make something to do the job of the sills before I cut them out. So on friday a few bits of tubing quickly did the job:
These were braced to the floor to, and the Sills could then be removed.
The inner sills of the volvo also needed cleaning up of any remaining metal. This was a really hard and messy job, and still not finished completely yet.
So, after cutting out the bulkhead and main floor crossbeam, it was now time for the shell to come off of the rotisserie and start lining up with its new suspension.
A bit of fiddling and trimming, and an hour later it is even closer:
You can see in the image below, that there is still a little way to go until the shell and the Nissan suspension are joined, but it is getting closer, and I hope by next weekend to start on the fabrication to join them together permanently.
