Hmm, I would suspect that if you had holed a piston then it wouldn't run properly on 4 cylinders, but I am not an expert :!:
Let me know how you get on, are you taking it to Zak's for some diagnostics :?:
Anyone doing the AEMC hethel round this Sunday??
The pistons can burn down the edge of the ring land and lose compression that way. Of course I could be very wrong but these engines do run on 3 and a bit. Pavlo ran a very quick time at TOTB with one piston down.
I'll do a compression test before anything. I've been trying to contact Zak for over a week, on another matter, and can't get hold of him.
Andy, second in class (out of three) doesn't mean much when you look at how quick Mike B went
There was a lot of time to be gained all round the place. But not by me
Adjusting the KWs is dead easy btw. 2mm allen key in the top of the rod and 4mm key in the bottom of the strut. Clicks are not easy to feel or hear but there's only two turns from full soft to full hard. HTH
I have a tester thanks Andy, just no time to use it.ESL wrote:Ive got a suitable compression gauge if you need one, fingers crossed it isnt that.
Did you notice the difference after adjusting the shocks?
The shocks were better on the softer setting :roll:
Hi Gerry,
Sorry to hear you had a problematic day, but sounds like you still had some fun.
Hopefully see you Wednesday
Thanks Eddy. I was looking forward to Weds to do some testing.
Try the rally slicks back to back with the 888s.
Try a few damper settings.
Finally see whether the oil temp gauge still shows silly temps now that the sensor is replaced.
