RS Central Day
That's cool mate:)
We're comparing degrees of front end lift. The front end lift on launch and under load was significantly less than in the past. Every photo of the car on track and at the pod shows it speed boating. The car was behaving more like a fwd car. Which cause understeer on corner exits.
(Hence changing the map)
The next step after suspension would be, drop links, adjustable TCA and a bladed wrc anti roll bar.
So, we are looking to keep more of the tyres on the front pressed into the track under load and also to keep the car much flatter through the corners. Santa pod just helps us to see the car under load through the gears.
