Track Evening @ Snet 19th June *PAYMENTS NEEDED
- Datsun-Des
Virgin session is for those who have NEVER done a track session before - unless I'm mistaken ...
It's to give all those the opportunity to be out was people in exactly the same boat.
Stu, Dunk what is your opinion .. is it a pure virgins session or a virgin / semi virgin session?.
The numbers are quite low, so I'll go with Dunk on this one.
You guys need to be sensible about it. If you are too quick or aggressive for your contemporaries, you will be pulled in and you will miss that session.
Think carefully before you go into a lower group. We will protect the slowest drivers there. Of that you have my guarantee.
- Datsun-Des
What's the situation if you get pulled? No more sessions? Moved into the Vets group?stuart wrote:The numbers are quite low, so I'll go with Dunk on this one.
I only ask as I could be quite quick, having said that I have not been on track at Snetterton or in my own car so I certainly wont be fast to start with. I'm just cautious of being pulled if I show a bit more speed than others.
