Marham trackday 2012
It's a relatively clean runway surface mate so much better than an airfield but nowhere near Snetterton's level of prep. The areas of the track that criss-cross over the runway is more abrasive and this is where you may pick some small stones up. I've driven everything from the mk2 white, the mk2 black and the M3 there. I even took the mk2 white back and Ben and I gangbanged it!!! If you are fairly open minded about tyre destruction you can get an incredible amount of laps under your belt and this is the main 'issue' with the event. You can almost get too much track time! It's the longest back straight I have ever seen and I would expect that you'd get 140+ out of the Cupra there. If you allow plenty of time for cooling purposes you should have no real dramas at all.
The event is run with real precision in terms of infrastructure. The catering is great and the atmosphere is very relaxed. Some of the posh boys don't like getting a NATO M3 fired up the inside of them :D but generally they are very accepting of 'differing' levels of commitment ;)
I reckon Marham has to be done at least once. It is cheap, it is fucked up fast and it is a real laugh. Add in to that the great cause it supports and the variety of cars there and it quickly becomes an essential part of the calender.
BIGBIMMA
Post by BIGBIMMA »
:iagree:
done this for the last 4 years and always have a great day .
check out youtube for loads of footage ,
if you go you will have a right giggle ,:smilielol5:
cheap as chips and this year they will be reversing the track layout at lunch
Good enough for me.
Thanks guys.
pedGSR
Post by pedGSR »
i would really like to give this a go this year. how quick does this normally fill up?
das ist kaput!
1994 Mitsubishi lancer evo2 gsr IN BITS AGAIN
1988 Toyota mr2 1.6
1997 540i v8
ChrisR
Post by ChrisR »
I shall also be attending with RobS although i doubt i will have anything to track by then so will be purely spectating! Looking forward to it though!!
i might well be up for this even if its in piere :)
Shame you can't spectate there. Would've loved to come along and see what's going on. :)
Tonynos
Post by Tonynos »
Daniel wrote:Shame you can't spectate there. Would've loved to come along and see what's going on. :)
I agree it is a shame. Sure you could get one of the guys to take you as a passenger Dan.
Tony.
If I do attend I'l be passing through thetford on the way.
mikeb
Post by mikeb »
Hopefully if the golfs ready will do this again would be a good place to iron out some of its issues after its rebuild.
life rules
