Hello boys and grills My name is Jay and i am the proud owner if not driver of a 32GTR skyline The story is long painfull and somewhat boring but rest assured summer07 WILL be the year i get the baby on the road for good and start using it in the fashion it was intended See you all soon but for now Thats me ,The replies will be you and the fun will be all ours
Jay
8)
refugee from GTRoc PMSL
Welcome to the site Jay
Looking forward to seeing and hearing more about the car(mark 3?) You'll have to pop along to one of the events when you get the chance :thumb:
Stu
Stu
Well to be honest the whole story can be found on GTRoc but the short version goes like this
Buy fresh import and have it serviced by someone who sets boost at 1.5 (std tubbies blow at 1.1+)
Blow fist set tubbies and get away with it
Fit second hand but good tubbies but not learnt about the 1.1bar rule yet
Blow second set and dont get away with it
Destroy pistons rods and bores
Lose faith for a year and then find APTuning :-)
Start rebuild of engine and get carried away
Run in new engine on new steel tubbies and its like honey
Spin a shell and back for a new crank and rebuild with some more nice bits for good measure
Run in fresh engine now like honey with big nuts in
Write off the car due to frazzled hicas computer and right foot
Buy car from insurers and strip all the good bits sell of the rest
Buy new car sell dead engine etc and fit my engine
Get caught up in the hunt for power and sell small tubbies to use the HKS2530s off the replacement car
Find out they are buggered and spend 9 mths deciding what to do
Big single or complicated twins
Car in driveway dead waitin for me to spend circa 5 k on it AGAIN
spec so far
Apexi turbo timer
Apexi Power FC
HKS hard pipe kit
HKS downpipes
Greddy adjustable pulleys
Greddy profec b boost controller
Greddy clear cam cover
Greddy air deflection plate
Greddy big sump kit
Sard 800cc twin hole injectors
Sard FPR
Sard 285 lph pick up pump
Sard custom swirl pot with twin Sard 285lph internal pumps
Nismo street series exhaust inc Decat
Nismo oil pump
Nismo N1 water pump
Nismo engine mounts
Nismo adjustable front top arms
Nismo front tie bars
Nissan shells
Nissan z32 afm,s
Scholar engineering balanced std crank
Scholar engineering reworked head inc squish removal
Tomei fuel rail
Tomei hicas lockout bar
Tomei Super grommet steel gasket set
Tomei pon cams 260 in 260 out
Tomei timing belt
Tomei forged pistons
Tomei forged H beam rods
OSG twin plate with new plates
Cusco breather catch tank
Cusco front and rear strut braces
Cusco brake stopper
Tein super street springs
Ohlins adjustable struts with pillowball tops
Arp rod bolts
Circle earth system
Solus air intake kit
Aeroquip all over the show
Rising sun fuse cover
Headlight vent with Fireblade headlight
Bailey motorsport alloy header tank and washer bottle
Koenig 17" x 9.5j 3 piece alloys
maybe this lot should have been on a separate thread
sorry mods :roll:
most of the story here http://www.gtr.co.uk/forum/upload/41848 ... -come.html if you really wanna know the gruesome details
Jay
spec so far
Apexi turbo timer
Apexi Power FC
HKS hard pipe kit
HKS downpipes
Greddy big sump kit
Sard FPR
Nismo oil pump
Nismo N1 water pump
Nismo engine mounts
Nissan shells
Nissan z32 afm,s
Tomei fuel rail
Tomei timing belt
Cusco brake stopper
Arp rod bolts
Circle earth system
sorry mods :roll:
Jay
Hi Jay
and welcome - from the parts you've listed above that is going to be a hell of a beastie - best of luck with the nuts and bolts
~Mark
~Mark
