hello all
Posted: Fri Apr 25, 2008 9:00 pm
by rosswilson
hello to all, the name is ross and i have not long owned a impreza wrx sti version 1 currently just over 300bhp soon to be over 500, still need alot of bits tho but i will get there.
Posted: Fri Apr 25, 2008 9:02 pm
by duncan
Hi Ross
Sounds intriguing, who is doing the work on the car? and what is going to get you up there spec wise?
Posted: Fri Apr 25, 2008 9:50 pm
by Gerry H
Welcome Ross. Long climb up to 500. What's planned?
Posted: Sat Apr 26, 2008 6:13 am
by Mr Fletcher
hello and welcome to bigpower 8)
jason
Posted: Sat Apr 26, 2008 6:44 am
Hi Ross
Welcome to the forum. I'm sure you're aware of how big a jump 300-500 is, both financially and from a driving point of view, Sounds like a lot of fun
Best of luck with your project........what do you use the car for apart from day to day stuff? Presumably there is a purpose for the power.
Posted: Sat Apr 26, 2008 7:42 am
by Ben
Hello and welcome to Bigpower
Posted: Sat Apr 26, 2008 10:44 am
by rosswilson
a friend of mine builds subaru rally cars and evo`s, and another has 20 exp in jap tuning
pisstons
rods
bearings
gt30r
injectos
fuel rails
apexi power fc few other bits and bobs fmic ect,
got to twish the turbo, i was looking at raising the inlet and moving the powerstering res, but it will still not have enough room to fit the pipe,
i have the colsed deck block with ballenced crank ballanced flywheel uprated injectors fuel pump fse,
the lad i bought my car off has done the same as above and is pushing 560bhp with an md321
and the rebuild is very cheap for labour charges, should be starting in the next 3-4 weeks, all keep you poased
