Hi from the Norfolk-Suffolk borders
Individualist
Post by Individualist »
Thought I'd just say hello to everyone as I'm relatively new to the site. I'm David and drive an R32 GTR - tbh it's more of a street spec. car than a track car ( :o the paintwork!!) I'm mainly found on SOC, where I'm quite heavily involved, & GTROC. I know you guys like a spec. list and piccis so here you are. She's currently running 470 bhp atw.
GARAGE Saurus tuned R32 GTR to stage II
Apple candy red (hoc), low mileage 1992 R32 GTR tuned by Garage Saurus in Japan to stage II with initial UK upgrades and restoration by NewEra, GtArt and RK tuning.
Maintenance & continuing development by GBH Motorsport.
Autostyling by BBS, Colchester.
Full inspection service on arrival, July/August 2006.
Engine Specifications:
2.5 twin turbo: Initial mapping by Gary at GtArt on RR for UK fuel. Remap for cams on the fly by Dave at RK tuning. 417 hp atw on 1.35 bar @ 7,500 revs. /339 ft lbs torque @ 5,600 revs at GtArt prior to HKS step 1 cams & Apexi electronic boost control kit. Abbey MS complete remap on 23/6/07 474 ath @1.2 bar (6,800 revs)/418.7 ft/lbs torque @ 5,392 revs
Engine Misc.:
HKS Intercooler and piping, heavy duty metal gasket 1.2 mm., Greddy aluminium alloy radiator with nismo thermostat and hoses in red, Nismo uprated radiator cap, Trust/Grex oil cooler and remote oil filter kit [new UK fit, '06], remote HKS twin ignition amplifier & harness [new UK fit], NGK Racing iridium spark plugs [new UK fit], Rewired RSM [UK], earthing kit removed, new lambda sensors x2 [July, 2006].
Cambelt change on age, not mileage [new UK fit @ 38,463 miles, July '06].
Complete engine check by GtArt, August '06: compression tested, 'O' rings checked & coil packs cleaned & checked.
Mobil 1 15w-50 engine oil on arrival UK and every 3,000 miles. Changing to Silkolene Pro 10w-50.
Coolant change.
Engine bay steam cleaned UK 23/6/06 with electrics protected.
Tomei Steel gaskets for inlet plenum [RK tuning 9/06]
HKS step 1 cams, pulley and vernier kit, & remap for cams [RK tuning 9/06]
Cam covers, inlet plenum,induction piping & fmic pipes powder coated black [RK tuning 9/06]
RK tuning oil cap
FMIC refresh prior to light silver respray
Turbocharger & Induction:
Nismo N1 turbos, Apexi dual funnel oil impregnated mesh filters.
Fuel & Tuning:
Sard 700 cc. injectors (new UK fit,August 2006), Nismo uprated in tank fuel pump, Nismo fuel pressure regulator and steel braided hosing, modified standard fuel rail, standard R33 GTR AFMs [new UK fit], Apexi Power FC and Commander mapped for UK fuel [UK fit],
Apexi boost control kit wired to read through PFC commander [RK tuning 9/06] Fuel: Shell V-power only.
Exhaust:
HKS high flow exhaust downpipe, dual silenced high flow system (with Chrome Hearts cat. replacement pipe [UK fit])
Drivetrain:
Twin plate clutch with alloy pressure plate and lightened flywheel.
T.S. Dancer Grid 4WD Controller: Attesa/ RWD/ 50:50torque split.
Skylab Torque Split Controller Vers.II (9/07)
Tomei hicas lock [RK tuning 9/06]
Fluids:
Redline Heavy Weight Shockproof gearbox oil, fully synth. diff. (x2 diffs.) 75w-90 & trans. oil fully synth. Motul Dexron 3 changed prior to GtArt map.
Motul Dot 5.1 brake fluid with fitment ap racing bb kit (9/06) Bled & changed with fitment ss lines (07/07)
Suspension & bracing:
Tein Super Street suspension with adjustable front links(July, 2007 - GBH MS)
Cusco alloy strut braces front & rear
Cusco uprated anti-roll bar
Computerised alignment of suspension, camber & castor adjustment following tyre upgrade from 255 to 265s by SCAI. Rolled rear arches (10/06)
Custom mounted rose jointed front tie rod bushes (Feb.,2007- GBH Motorsport)
Inspection of rear sub frame bushes, condition report on steering rack components (Feb.,2007- GBH Motorsport)
Suspension set up adjusted for UK roads with corner weighting (July, 2007 - GBH Motorsport)
Brakes:
ap racing 6 pot big brake kit (black) 343 mm disc due to rim structure and Dpa grooved rear discs with std. nissan callipers [RK tuning 9/06], Nismo steel braided brake pipes (July, 2007 - GBH MS)
Rims:
WORK Meister S1 2 piece split rim deep dish alloys with colour coded spokes. Full split down rim refurb.(01/07) Large centre nuts/bolts sprayed black. Works rim stickers in silver. Red anodised 'Works' lug nuts matching ap racing bells.
Tyres:
Toyo Proxes T1-S 265/40/18s
Weight Reduction:
nil
Interior:
Black and red leather custom interior, including retrim to original GTR dash, door cards, centre console, gear & brake surround, centre compartment, steering wheel, headlining and rear parcel shelf.
Apexi Rev Speed meter & optional G sensor incorporated into dash, Vivid fuel pressure & boost pressure gauge in re-modelled glove compartment with red leather trim, Nismo 180 kmph white dial facia with ice blue or green light option, Nismo gear knob in black leather, custom painted kicker plates in candy red & gloss black, interior plastics in gloss black including seat trim, new R34 GTR original floor mats in black trimmed with red leather and custom black leather with red stitching boot retrim including secret storage compartment and removable black floor carpet (09/07).
Alpine CDA 9812RB headunit driving x2 Alpine SPR 136A 6" speaker sets front & rear.
Exterior:
High quality Window tint installation: light smoked front side windows to medium dark rear quarter and rear window (09/07)
Nismo bodywork incl. bonnet lip, boot lip and intercooler vents
Original N1 Model spec. headlights (restored 01/07)
D-Speed clear front indicators and Wise Sports LED rear lights [new UK fit]
Undersealed on arrival UK
Incorporation of rear fog lamps wired into rear light cluster
Fibre glass rear boot lip replacement remodelled by BBS and new nismo OEM front bonnet lip replacement (12/06)
Underbody sprayed in satin black (01/07)
New seals to front and rear windows (01/07)
New interior & exterior rubber door seals (01/07)
New exterior weather strip to doors (01/07)
PIAA Sporza carbon style wiper blades (03/07)
Improved refit of nismo bodykit and restoration work to front bumper including new fixings
Complete respray in House of Colour Candy Apple Red and silver ground coat with custom 'Garage Saurus' logo to the rear, rear GTR de-badged and satin black respray to underside of the bonnet, boot and shuts
Underbody & arches sprayed satin black & re-sealed on completion of respray
Replacement GTR rear quarter spats (08/2007)
Nismo kit external fixings replaced with red anodised mushroom headed speed bolts colour coded with ap racing brake bells (09/07)
Rear tow loops in black
Ganador mirrors
Replacement mint GT wing badges
New OEM Skyline bonnet ornament in gold & candy red enamel
Max Power featured June edition, 2007
Banzai feature July edition
Garage Saurus R32 GTR
Rnash2002
Post by Rnash2002 »
The blue is hurting my eyes :grin: great write up and welcome aboard. :thumb:
Individualist
Sorry for that, I should have known better on a Sunday morning - now you're just blinded by the red :wink: :)
Great spec and a lovely example of a GTR.
I remember seeing the interior pics that Mattt took a while back and wondered when it would turn up on here - glad you have sorted the log in issues :thumb:
Fast Eddy
Post by Fast Eddy »
Welcome mate and credit to you for your super clean example. I was at santa pod when you were having those pics taken.
I woud say that you you have great power for that level of boost now and plenty for some track fun, but perhaps your car is too tidy for that.
Liking the sound of the 11th run and sure a few other BP members will be too.
Hello mate, welcome on board.
Individualist
Yep, might have to see if I can get something else for the track :lol:
You'd be more than welcome to come along on the 11th, Eddy - the more the merrier! :D
RobCallow
Post by RobCallow »
Hello and welcome to BP :-D
Rob
rolty
Post by rolty »
Hi there - welcome to Bigpower.
I live in Wells so I'll be sure to come down and have a look when you arrive :D
Bubble
Post by Bubble »
Good to see that you made it over here OK David :-D
Geoff Boston R34GTT RB30
__________________________
