subaru breakers
Posted: Fri Feb 26, 2010 5:58 pm
by DR GREENTHUMB
Does any one know the subaru breakers in brooke , norwich ??? not sure if they are a trader / member on here or not. Just need a few bits . Have e mailed rob at go faster but not sure if he has what i need just yet. Any help would be great :)
Cheers , matt .
Posted: Fri Feb 26, 2010 6:54 pm
The breakers are not traders on here Matt. Rob and Ben at GOFASTER may be able to help as they still have a few Impreza bits in stock.........I think Russ may know of someone who can help if not :)
Posted: Fri Feb 26, 2010 7:27 pm
by DR GREENTHUMB
Cheers big man ;) might pop in and see rob tomorrow .
Cheers , matt .
Posted: Fri Feb 26, 2010 7:36 pm
by Jon
Dale & Duncan at Brooke provide an excellent service. Everything I've needed from engines, Gearbox's, Brakes etc etc they have either had in stock or will source very quickly.
When everyone said that it wasn't possible to wire up a WRX loom to STI AVCS engine/ECU, Dale managed it in under an hour. Good guys to deal with. Just my 2p's worth.
Posted: Fri Feb 26, 2010 7:53 pm
by Gerry H
Might help if you said what it is you need. :)
Posted: Fri Feb 26, 2010 8:03 pm
by DR GREENTHUMB
I need the metal pipe that runs from the filler neck to the tank & an o/s/f caliper . I have repaired the caliper once with new piston & seals but its sticking again , the metal pipe has just started to weap a little .
cheers , matt .
by russ979
Not wishing to take anything away from the traders on here, But Dale at impreza breakers is a top bloke and if you speak to him do please mention me and my yellow scoob (he looks after us in exchange for his number being plastered down the sides of my car!) he may well cut you a good deal:thumbs:
Posted: Fri Feb 26, 2010 9:56 pm
by Andy916
What is his number, Russ, and whereabouts are they based?
Andy
Posted: Fri Feb 26, 2010 10:02 pm
by russ979
Oh the shame of it! I actualy had to go outside and get the number of the side of my car- its only been on there a year!:blush5:
www.imprezabreakers.co.uk 01508 558880
Posted: Fri Feb 26, 2010 10:04 pm
by Andy916
That was quick!
Thanks Russ.
