The how to thread
The how to thread
This thread is solely to reply to questions posted in THE HOW DO I THREAD.
READ THE INSTRUCTIONS FOR USE in the how do I thread and then post your CLEAR/CONCISE answer in here using the same sub heading as the question.
This could actually work (as I'm a naive fool) and save cluttering snag lists and other threads with random info.
So to start:
PMs
Check your settings in User CP \ Settings and Options \ Edit Options \ Messaging and Notification \ Private Messaging.
Smilies
Smilies are available when replying from the 'Go Advanced' reply box.
Change the forum colours
There is also an option to change the colour of the 'skin' now.
Simply go to the User CP or Quick links above and hit 'Edit options'
Scroll to the bottom and select 'standard' skin. Et Voila. Black text (although that can be edited like you would an email) on a white background.
Ta
