anyone had any experiance fitting an avcr , im useless with instructions :lol: and knowing me will do something stoopid and frazzle it
beer tokens on offer for assistance
it all looks ok and straight forward until i got to the splicing into the ecu wires :?
help fitting apexi avcr boost controller into pulsar
If you have the ecu pin-out diagram, it should be quite straightforward. Just make sure you get the right colour wire, from the AVC-R loom spliced into the correct ecu plug wire.
I don't think you can do anything catastrophic as you're only picking up the sensors signals for display, not putting anything into the ecu. the AVC-R outputs are direct to the solenoid valve.
Suppose you could cheat and use those bulky caravan connectors (can't think of the name but the side by side splicing thingys)
But do make solder joints to finish off
BTW, make sure you fit a scramble button for a little oomph on the low setting
rayman gtir
trev i could give you a hand, but wont be till the weekend, there is a pic of the ecu pinouts on the owners club.
http://www.gtiroc.com/forums/showthread ... uts&page=2
