any advice would be mucho gratefull!
GoPro **worlds smallest trackday camera**
do any of you have one of these? i bought one this week tried it today and the sound was crap to say the least, infact there was no sound it was only crackling all the way through, it says on the instructions to turn the sound to lo quality, but i cant find out in the settings how to do it
I miss my scooby
yup got it sorted now Dunc emailed Go Pro today and got a speedy reply back
Hi Duncan,
The HI/LO sound settings are found in the setting menu. To access the settings menu, press the power/mode button until you see "SEt" on the screen. At this point press the shutter button to enter the settings menu. Once in the settings menu, press the power/mode button to scroll through the different setting options. The HI/LO sound settings should be the third setting right after the frequency setting. The LCD screen will either read "HI" or "LO". Press the shutter button to switch between the two settings.
To exit the settings menu, press the power/mode button until you see "ESC" on the LCD screen. At this point press the shutter button and you will be returned to shooting mode.
If you do not have the HI/LO sound setting or UP/UPd camera orientation settings under the "SEt" menu then you could have our older spec camera which did not have these features. You can update your camera with the attached patch instructions.
Let us know if you have any further questions.
Many thanks,
GoPro Support
http://www.goprocamera.com
they even sent a patch to update it with just incase i had the older model which didnt give me the option to use the Hi-lo setting, just tested it just now and the sound has improved no end, it dosent like night time though, i could hardly make out any street lights with it not that thats an issue though as i will never use it in the dark anyhoo, top bit of kit so far me thinks will give it a better test tomorrow me thinks
Hi Duncan,
Many thanks,
GoPro Support
I miss my scooby
