Spec of the car incase parts start showing up
Engine
Trust 87mm Forged Pistons
Tomei Rod Bolts
Tomei 1.2 layered metal Head Gasket
Nismo N1 Bearings
Nismo Oil Pump
Tomei Sump Baffle
Tomei Valve Guides
Tomei Inlet Gaskets
Tomei TB Gaskets
Tomei Exhaust Gaskets
HKS Turbo Gaskets & Fittings
Garret GT2860R twin turbos (-5)
Tomei Pressure Regulator
Blitz DSBC-iD III
SkyLab TSC Evo
Fujitsubo Giken Exhaust
XS Performance Downpipes
Mocal Oil Cooler & Remote Filter (ThinkAuto kit)
RIPS catch tank
red samco hoses
Greddy hard pipes
TEIN RS Circuit Master coilover suspension with rebound/compression adjustment and remote reservoirs.
2 EDFC units (fire damaged rear cables, 1 EDFC control unit with 'R' marked on it, the other with 'C')
Nismo Rear Arms
Front & Rear strut braces
Ksport 8 piston calipers and 356mm discs
Ferrodo DS 2500 pads
Ultralite Battle 17x9 et17 wheels in bronze. Both nearside wheels with kerbing, NS front with a dent.
Cusco Cage, anodised blue, with padding on front section. Cross bars chrome finish with DV camera mount attached.
2x tatty looking Corbeau ProSport bucket seats with no padding, with blueish powder marks from fire extinguisher.
New Ksport 6pt FIA harnesses, with blueish powder marks from fire extinguisher.
OMP 2l powder extinguisher
Varley RedTop 15 racing battery mounted in RedTop30 sidemount red box. Battery mounted behind/under passenger bucket seat.
Marks on bodywork....
Dent on front of bonnet, and small dent on nearside front wing.
Rust showing through on O/S rear arch
Blue paint on rear screen and rear 1/4
Pebble Dashed sills from kitty litter
3 speed holes in front bumper for oil cooler.
Suspension / brakes
Exterior / marks
Interior
engine
Any info greatly appreciated
