my xmas pressie from the cats arrived ...
I am going to fit it tomorrow :D
Apparently a 2kg weight saving over the std one so should be a noticeable difference 8)
Thanks puuuddies :)
Buttercup
Post by Buttercup »
Very nice. :)
How come my cats only bring me live mice and dead leaves??? :?
Impreza WRX STi, Version 1, No.33/200
1st Mod - replace orange front indicators with clear ones.
Is this a slippery slope?
You've lost me Dunk. What is this component? Very pretty in black I might say.....whatever it is.
Its a lightweight crank pulley Stuart :)
andycaca
Post by andycaca »
i assume it wasn't only me who glanced and assumed it was a wheel (of the type you wrap in sticky rubber)!?
Yep - I thought - where is the valve hole :)
jungle-jim
Post by jungle-jim »
you must have a fantastic pussy duncan!! :lol:
this should give back some bhp back too or slightly better acceleration i assume?
Buttercup
Post by Buttercup »
andycaca wrote:i assume it wasn't only me who glanced and assumed it was a wheel (of the type you wrap in sticky rubber)!?
Nope not only you.
lol at JJ :D
The standard crank pulley weighs 2.5kgs
This weighs 550 grams so saves 2kgs over standard in rotating mass so should accelerate better. I am not sure whether I will be able to notice it but every little helps :D
I have now changed it having fought to undo the crank bolt .. the fekker :x so will give it a run out later on.
edit... I have just weighed the std pulley and it is 3 kilos :o so a 2.5 kilo saving :D
