Battery re-location
Hugh Janus
Battery re-location
has anyone (specifically with a 200SX) ever used a battery re-location kit, if so is it easy to do? (please bear in mind i am shockingly bad with a spanner)
I have done this to my S12 Silvia a couple of weeks ago.
Only reason i did this was so i could fit an intercooler into the engine bay as the car was never designed to have one.
Its not too bad to do but you need a blowtorch and some big solder to join the cables and lots of cable!
Hugh Janus
I know a lot of people use the BMW E36 isolated positive terminal that sits under the bonnet that allows you to make a conection for the positive cable to run to the boot. The battery then earths out in the boot.
You need some sort of proper mounting or battery box for the boot.
You might find you need a slighly more powerful battery to compensate for loss in the extra length of cable.
I hope that this helps.
the request for a hole cutter and a battery relocation was a give awayHugh Janus wrote:yeah its to fit an intercooler, i have got a small Nissan Micra battery on the car already but I'm not entirely sure its small enoughgary@apt wrote:one or two people have done it,but i really dont see a need,if its so you can fit a intercooler then they do a battery that fits in sideways
we use a varta one the works with most intercooler kits,saves hassle
Hugh Janus
Hugh Janus
