Bought in mainly for adding to a basic GTR rollcage for a BP member, but will be very usefull for other work. It will bend up to 45 degrees without much deformation on thick wall tubing.
The test pieces as in the pic are 2mm wall stainless steel and it bent them no problem as i went for the 16 ton version over the 10 or 12 ton. It will adapt to bend solid bar and other sections of metal.
I will make bespoke strut braces, lower suspension braces, tunnel braces etc using high grade seamless tubing where necessary.
Let me know what projects i can help with :-D
