Started the car up this morning and petrol was peeing out from the side of the engine from around the injectors so suspected a split o ring or similar. Being as though I am not confident in my abilities to remove the injectors myself and then have the car in a fit state to run again, Ren offered to drive over to my house and help (read do it for me
Anyway to cut a long story short, it appears as if the fuel hose clamp was loose and this was the issue but the injectors were taken out and checked aswell just to be sure and some hosing re-routed to relieve some pressure on the hose.
End result is problem solved.
Cheers Mate and I owe you several beers at least :thumb:
