Is anyone on here equipped to cut an exhaust manifold flange or know someone that can?
I have a gasket as a pattern and it needs to be of high quality to go with a Stainless Tubular Manifold.
Help!!
Exhaust Manifold Flange cutting.....
Matt, I will call you in the morning (Tuesday), but wanted to post a pic of the shape of the CVH Exhaust Flange. Not sure if it needs the intricacies, but the current flange is 13mm thick.
Regarding the 'Ports' I would need to specify a size ideally, slightly larger than they are there, so that the tubes can insert into the flange and be welded inside and out.
Of course, if you think you can do the job and the Gasket is suitable as a pattern, I will send it to you.
:-D
:-D
