Hope you get it sorted soon Duncan, at least you were unhurt and that's the main thing. Not sure if you need help at all, but just shout if I can be of assistance.
Kev
In the armco (with pics now)
I'm sure you can get them working again by using the resistor method. Take one correct value resistor and solder each leg of it to the correct contacts on the connector that went to your OEM seat.
I'm sure that's right.
I've just had a look on ScoobyMods and you will have to do a couple of other bits too as yours is an MY06.
http://www.scoobymods.com/forums/showthread.php?t=7434
You may already have read this thread but i found it useful.
I'm very lucky i don't have any of that malarky to do on mine if i swap seats as my chair doesn't have any connectors underneath to mess with so no airbag light issues for me.
Good luck with that and spot on about the 3Ohm resistor :thumb:
