http://www.youtube.com/user/PedroFandan ... NUvkVbdxc8
Still has a bit more left aswell.
What Ive Been Upto.
Getting better Russ. I take it your boost is limited in first and second.......or was it just traction that was limited?
No boost limit just a torque limiter in 1st,i just need to get some better rubber and maybe shed a few pounds lol,i still have a couple of psi to add aswell so should be in the 13's soon.stuart wrote:Getting better Russ. I take it your boost is limited in first and second.......or was it just traction that was limited?
Ok thought i would update this again as ive just reached my goal figure,but not with out its problems lol.
Ok about a month ago i decided to go and get the afrs looked at on the dyno then i would up the boost alittle.
Well to my horror the car was running way to lean at the top end,the chap was very surprised i didnt do the engine.
So left in not a good mood and decided to change fuel pump,reg and maff.
Went again a few weeks later and was better but still out,i turned the boost down to 13psi and she made 273bhp and was still a tad lean.
So it had to be the map,i phoned the chap up who i got it off and he went on the defencive lol blaming me for not coming to him and saying i was told to look at the afr before i ran 1.3 bar,i told him im not even running 1 bar boost and its way too lean.
Well decided to get a fse to see if i could get the fuel sorted,went today and we got it as best we could but the map was still trying to pull it back.
She made 303bhp at 16psi and 340 torques,stil could be alittle richer higer up the rev range but im happy for now knowing that once we get the fuel sorted then it would probably see 330/340bhp a 1.3/1.4 bar.
Also made me happy was the fact i pulled a 14.0 @ 102 only running 280bhp lol,should should be into the 13's next month when i go again.
Link to dyno sheet
http://img.photobucket.com/albums/v489/ ... torque.jpg
Not to bad as ive added 50bhp from when i bought the car,so far anyway lol.
Link to dyno sheet
