Time Attack Club Challenge Rule Discussion
OK..... I'll calm down.... rant over......dynamix wrote:Mike - the OE seat rail seat belt mounting points will be acceptable, as will the rear seat belt points.
Clip in 4 point harnesses will leave the mounting bolts in the floor/rear so no holes will be there.
The bonnet pins are a pain but I was going to do this anyway as I have had the bonnet on mine pop up before and I dont fancy that on track.
Boot pins are not compulsory if there is nothing in the boot, ie swirl pots/pumps etc.
Harnesses dont need to be FIA approved - just SFI
seat belt mounts should be ok..... rear seat belt mounts ok....
bonnet pins....
Trust me a little more than two little holes, as the pins need to fix to the front cross member, then align properly with the bonet, and likely as not it will be half way across the inner support panel cut outs..... :?dynamix wrote:Its only two little holes mike or some rather swanky aerocatches
Dont worry about the cost of the passenger harness.
One of the series sponsors will be offering FAI harness's for
SM on TV !!! TA 08 Rd2
Apex, KSport, PPG and Hardrace Equipped, APT mapped Club Challenge S13 Time Attack Car
