Prince Graphite Tour tennis racket
Needless to say that this hasn't seen a lot of use (stop laughing :) ) but if anyone on here plays Tennis, you will know that Prince is still one of the top brands and this is also quite an old and collectable model.
The above is a library photo but principally it's the same thing, except mine has Prince Synthetic gut stringing and a Karakal overgrip.
It's a grip#4, 4 1/2" grip diameter and that's the factory size, so allow a bit for the old Karakal grip that's on top. The mid-plus head and 22mm straight beam frame is in really good condition with slight marks around the top, and some scuffs to the plastic frame protector which is, of course, quite common. The original carry bag is in good condition with working strap and zip. The frame still has the all important hologram certified manufacturing number too (i.e. this is not some cheap far east rip off that was prevalent in the '90's and 2000's.
The only one I can find for sale is on Gumtree and they want
Isnt this the 'Tennis racket formally known as Prince' ?!!!?
I should charge you
